1992 Jeep Cherokee removal of gas tank and installation of
1992 JEEP CHEROKEE
JOHN PENDER
1992 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
how do you remove the gas tank and install a new sending unit without it leaking from the metal ring that holds the sending unit into the tank?i removed the sending unit,reinstalled it and now it has a leak from the metal ring that holds the sending unit in the tank.
Jan 14, 2010 at 4:21 PM
  • 110,244 POSTS
Did you replace the rubber o-ring that goes between the sending unit and the tank?
Jan 15, 2010 at 8:00 AM
