1992 Jeep Cherokee Coolant leak
1992 JEEP CHEROKEE
JPARRISH
Engine Mechanical problem
1992 Jeep Cherokee 6 cyl Four Wheel Drive Automatic 165k miles
Las Vegas NV. heat it leaks 1 pint on a ten mile trip. It drips from the back of the trans. pan and the pan has coolant all over it. Cant see coolant on sides of enjine and heater hoses look dry, can't find signs of leaks other then trans. pan. If you have some ideas where to look will be helpful, Thank you, Don
Sep 17, 2010 at 3:04 AM
If its coming from in between the transmission and engine sounds like an engine freeze plug on back of the block -
Sep 17, 2010 at 5:24 AM
