1992 Jeep Cherokee checkn engine light
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
1975TODAND
plugs are ashed over with wight sutt first stard of day will start and run 10 - 20 seconds then die then next start will idel but when given gas will die unless start while giving gas thern shifting to drive and getting on it like i stold it.
Jun 11, 2010 at 6:41 PM
  • 75,988 POSTS
Hi 1975todand, Welcome to 2carpros and TY for the donation.
Inspect and test the automatic idle speed motor, clean out the EGR and PCV valves and test the throttle position sensor and manifold absolute pressure sensor.
Jun 11, 2010 at 9:07 PM
