1992 Jeep Cherokee Blown Fuses
40,000 MILES • 6 CYL • 4WD • AUTOMATIC
DALESHEATHER
I got a new battery and everytime I connect it the two 60 amp fuses blow. What could be causing this?
May 19, 2009 at 7:43 AM
JDL
  • 16,098 POSTS
Hello, there is a black wire with a white tracer, goes to the alternator. Unplug it, just for testing. My info shows two 60 amp fuses plugged into that circuit. Don't replace the fuses, use a testlite across the fuse terminals. If the lite comes on, your going to ground somewhere on that circuit.
I'm not sure we're both talking about the same circuit?
May 19, 2009 at 8:25 AM
