1991 Jeep Cherokee fuel
SSARZYNSKI
  • 1991 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 200,000 MILES
I have a 91 jeep cherokee 6cyl 4.0l,
it stalled when the car warmed up. I replace the fuel filter, blew out the lines, and cleaned the fuel injectors and fuel rail. It ran, but would stall after it warmed up. So I replaced the fuel pump, then I didn't get any fuel to the engine or in the lines, so I exchanged the fuel pump. II re installed foe the third time and still nothing. If the pump wires were wrong would you hear the pump? What did I do wrong or is it something I'm not thinking of?
Tuesday, October 21st, 2008 AT 12:12 PM
JNOVACK
  • 723 POSTS
No you won't hear the pump try this disconnect battery for 15 min and try again please let me know what you get
Tuesday, October 21st, 2008 AT 5:56 PM
SSARZYNSKI
I tried that and still nothing?
Wednesday, October 22nd, 2008 AT 10:54 AM
JNOVACK
  • 723 POSTS
Ok now check for power to the pump use a volt ohm meter and lets see what the volts are you also have a fuel pump relay under hood in the relay panel I fno power to wire to pump check the relay
Wednesday, October 22nd, 2008 AT 11:20 AM
SSARZYNSKI
I switch the relay with another one, and I get a volt reading by the pump at 7.5xx
Wednesday, October 22nd, 2008 AT 11:28 AM
