1990 Jeep Cherokee Trany swap
213,000 MILES • 6 CYL • 4WD • AUTOMATIC
WYTE
I have a 90 Cherokee with the vaccume transfer case system (no id tag so not sure what is exactly) and ripped out third and forth gear. so i bought an 89 cherokee to switch trannys but niether of them still have the id tag on the tranny and i cant tell if they are the same, they look the same but im not sure if they will bolt up the transfer case beacuse the 89 has a np242 t-case which does not have the vaccume setup is there any way to tell if would work other than just takin out and tryin it...
Oct 10, 2008 at 11:38 AM
MERLIN2021
  • 17,250 POSTS
There were two trannys an Aisin and a peugoet, Check the shape and bolt patterns on the oil pans. it should fit either way.
https://images.2carpros.com/forum/automotive_pictures/62217_pan2_2.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_pan3_1.jpg
Oct 10, 2008 at 11:49 AM
