1990 Jeep Cherokee thermostat
AMANDAWMT
Engine Cooling problem
1990 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
I am trying to find out if the thermostat in my jeep is in the front or in the water pump. I'm pretty sure it's in the front but I'd like to find out before I start taking it apart.
Apr 10, 2009 at 11:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Replacement procedures are below for your vehicle's thermostat, so you won't waste time removing unneccessary components..
REMOVAL:
Disconnect the negative battery cable.
If necessary, disconnect the coolant temperature sensor electrical connector.
Disconnect the upper radiator hose from the thermostat housing.
Remove the attaching bolts and lift the housing from the engine
Remove the thermostat and gasket.
INSTALLATION:
Clean all gasket surfaces thoroughly.
Place the thermostat in the housing with the spring inside the engine.
Install a new gasket with a small amount of sealing compound applied to both sides.
Install the water outlet and tighten the mounting bolts to 200 inch lbs. (23 Nm) on V-8 engines and 15 ft. lbs. (20 Nm) on non-8 cylinder engines.
Install the upper radiator hose to the housing and tighten the hose clamp.
Connect the coolant temperature sensor connector to the housing.
Refill the cooling system.
Thanks for using 2CarPros.com!
Apr 10, 2009 at 11:47 AM
