1990 Jeep Cherokee front brakes
176,000 MILES • 6 CYL • 4WD • AUTOMATIC
RICKYBOBBY740
  • 6 POSTS
my back brake are not working could u give me what could be causing this to happen they dont even expand when i hit the brake
Mar 10, 2010 at 11:59 PM
CJ MEDEVAC
  • 11,000 POSTS
see my profile
air in lines...bleed system
no brake juice in reservoir...add juice and search for leak
pads/ shoes worn out
broken/ hole in brake line...find and repair/ replace
crimped brake line or hose...replace line
improper re-assembly of brakes, when it was
apart...install correctly
master cylinder malfunction/ worn/ broken...rebuild/ replace
proportioning valve malfunctioning/ stuck/ broke...repair/ replace
hope something here, works for you !!!
Love, Turddog
Mar 11, 2010 at 2:57 AM
