1990 jeep cherokee 4wd 6 cyl
1990 JEEP CHEROKEE
YOSOYPADRE
the car will turn over but it wont keep running, it dies after you let go of ignition. before it did this it had idling problems ( too low ) and would sometimes die. when it finally died on me it went about 15 mph and then reved to higher rpm's and choked out but wouldn't go nowhere. i got it to start again after that but it went like 100 feet, died, and would not start no longer. i already replaced the idle air valve, throttle positioning sensor, and the alternator. there is no vaccum leaks and all fuel and oil pressure is optimum. what could be my problem? i thought maybe o2 sensor or distributor sensor if your advice works i sincerely will donate i'm sorry ican't afford to pay anymore money for help that doesn't work i've done enough of that
Jul 7, 2007 at 7:52 AM
SAMUELJE93
  • 14 POSTS
The MAP SENSOR could be a possibility but don't take my word for it. Ask around for other opinions about this possibilty. It cost about $50.
There are so many sensors on these things and I spent a small fortune trading out parts trying to figure the problem on my 89 Cherokee. It turned
out to be a 50 cent piece of hose on the fuel pump!
Where are you located? Could be a possibility that I could loan you some of the parts I have, to help you find your problem. I would have to know a little more about ya just so I can trust that you would return them once you are through. I realize this may sound a little to trusting and maybe foolish on my part, but I have been there and I know the expense and frustration. I am a lower income dad with 5 kids and could not afford to take my Jeep to a garage but at the same time, I couldn't afford what I spent on parts either. But, I had to have a way to get to work. Anyway, you can respond on this site or email me at samuelje93@yahoo.com
Jul 7, 2007 at 8:13 PM
