1989 Jeep Cherokee what could it be?
172,000 MILES • 6 CYL • 4WD • AUTOMATIC
LIVE1LIFE
i have a 89 jeep cherokee limited. it started vibrating really bad only during acceleration at about 30mph. i found out that my driver side motor mount was bad and my tranny mount was bad, so i replaced both and it still shakes during acceleration, just not as bad. what could it be??[img:dd47073c0b]http://www.2carpros.com/forum/automotive_pictures/179102_01020001031201041020080114b915651c0f5d2724510055a7_1.jpg[/img:dd47073c0b]
May 1, 2008 at 8:10 AM
MERLIN2021
  • 17,250 POSTS
So you did check all three mounts right? If they are all good, check the front end, especially the track bar.
May 1, 2008 at 8:15 AM
  • 75,988 POSTS
When was the last time it seen a major tune-up? For a start check the throttle position sensor
May 1, 2008 at 8:16 AM
MERLIN2021
  • 17,250 POSTS
Is it a motor shake, skip? or a front end shake?
May 1, 2008 at 9:16 AM
LIVE1LIFE
i checked the two front motor mounts and replaced the tranny mount above the cross member. where is the 3rd mount located on the motor?
May 1, 2008 at 10:13 AM
MERLIN2021
  • 17,250 POSTS
The third is the other motor mount...I.E. 1 on each side, and your tranny!
May 1, 2008 at 10:20 AM
