1989 Jeep Cherokee Transmission Cooler Line Leak
999,999 MILES • 6 CYL • 2WD • AUTOMATIC
HAYDAVE7
I want to replace the transmission cooler line from the hard line to the radiator.
This is "the flex line" that interfaces the moving engine / transmission / power train to the rigid and fixed cooling system. ( so the dern thang does not fall apart with motion )
I do not like their cheap "quick connect" design, which allows them to have a faster assembly line, but is poor engineering as it degrades and starts to leak with age at the O rings.
I thought about just sawing it off, but instead "can I / should I " REMOVE THE LINE ( which needs a tool that I do not have ) and then just slide the 3 / 8 inch transmission oil cooler line OVER THE CONNECTOR ?
My problem is I cannot find a direct and NEW replacement for that part and a used one may be just as defective.
What do you recommend ?
1) Saw off the connector and try to connect over the "nub" ( only one connectors width to work with )
2) Try to remove the connector EVEN IF I DAMAGE IT, and slide the line over the connector.
I hope to use two steel banded adjustable clamps on each end to hold the NEW 3/8 flex line on.
I do not have the money to have it done by a real mechanic.
ALL ANSWERS WELCOMED !
( some of you "do it yer selfers " have done this )
Please advise,
dave :'>
Dec 1, 2008 at 12:49 PM
MECHCURT
  • 184 POSTS
I have replaced alot of tranny lines by just cutting them off and replacing with two hose clamps on each end. Make sure you use a hose made for tranny fluid and not fuel line hose. I have never had one come apart. Let me know what you do.. Hope this helps curt
Dec 3, 2008 at 9:49 AM
HAYDAVE7
[quote:64496683be="mechcurt"]I have replaced alot of tranny lines by just cutting them off and replacing with two hose clamps on each end. Make sure you use a hose made for tranny fluid and not fuel line hose. I have never had one come apart. Let me know what you do.. Hope this helps curt[/quote:64496683be]
GOOD SUGGESTION. That is what I did. I made sure to get 3/8 TCL ( Transmission Cooler Line ) and used 2 clamps on each end.
I did not lose much fluid.
Good answer.
Thanks !!!
dave :'>
Dec 3, 2008 at 9:57 AM
MECHCURT
  • 184 POSTS
Glad to help Dave make sure and put in a good word for me would you, just getting started with this site. Thanks Again Curt
Dec 5, 2008 at 5:12 AM
