1989 Jeep Cherokee tranny coolant line
214,000 MILES • 6 CYL • 4WD • AUTOMATIC
DESIC
the transmission coolant line is leaking i was going to replace it with a piece of 3/8's hose, but it still has the origanial factory seals, is there any way to pop the seals with out messing anything up? ( had this problem before and split the metal line on a previous vehicle)
May 27, 2008 at 1:05 PM
  • 31,937 POSTS
Hi there,
you will need to retain the clip and seal in the union at the transmission, or you will have no end of problems with it leaking. I would recommend you replace the pipe as a complete item and not use hose.
mark (mhpautos)
May 27, 2008 at 5:56 PM
DESIC
the section that is leaking is a piece of hose that is approx. 8 inches long, and is held in place by factory seals...............
Jun 8, 2008 at 9:31 AM
