1989 Jeep Cherokee TAPPING IN MOTOR
95,000 MILES • 6 CYL • 4WD • AUTOMATIC
JTH13
MY 1989 jeep cherokee has a tapping noise but not constent i have had people say it is a lifter and its not a problem and others say it could be a problem
also i have a whistle that goes away when giving the car gas but comes back we i let off
Dec 3, 2008 at 6:12 AM
MECHCURT
  • 184 POSTS
The jeep inline 6 is a great motor and can go alot of miles with regular service and maintenance. But somtimes things just where out and weaken over time. Sounds like a lifter has just gotten a little weak. After being driven awhile it quites down. Just normal wear on the lifter itself could cause this or it might be getting a weak oil pump. Probably not. Also the pushrod for this lifter may be clogged up a little and not passing the proper amount of oil. What weight of oil are you running?? You may add some STP at normal oil changes and lesson the noise a little, and you might need to tighten the tappet down just a touch on that one valve. The whistling??? Is this in the engine compartment?? Sounds like a vaccuum leak to me. Check all your vac lines in and around the intake. Let me know if this helps. Curt
Dec 3, 2008 at 9:14 AM
ENGINEMAN 73
  • 28 POSTS
ADD THIS TO THE GREAT ADVISE THE TECHNICIAN HAS GIVEN YOU. I HAD A KNOCK IN MY JEEP ENGINE AND THOUGHT I HAD SERIOUS PROBLEM. ON A WHIM I JACKED UP TRUCK REMOVED FLYWHEEL INSPECTION COVER AND CHECKED TORQUE CONVERTER BOLTS AND 1 HAD BACKED OUT TAPPING BLOCK.I WAS A HAPPY CAMPER. MAY NOT BE THE CASE WITH YOURS BUT WORTH CHECKING.
Dec 3, 2008 at 9:38 AM
JTH13
thanks for your input
Dec 8, 2008 at 7:42 AM
