1989 Jeep Cherokee Clunking noise when I turn
DEANTHOMAS1970
  • 1989 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 129,000 MILES
Hello, I am trying to figure out what is causing this loud clunking noise when I turn.
I have examined the front end myself and I found that the steering(tie rod ends)(Ball Joints) are tight, the clunking sound is accomponied by a slight movement of the wheel, as if something inside is shifting a bit, the knock is only present when the truck is holding its own weight, it does not make any noise when up on jack stands.
I am thinking it is the CV Joint on the drivers side, but im not sure, and what Parts & Tools I may need in addition to the joint itself.
any advice would be a big help.
The vehicle Vin # is 1J4FJZ8LXKL557317
Thanks in advance. Dean
Friday, May 16th, 2008 AT 12:10 AM
LEGITIMATE007
  • 5,121 POSTS
Yes it sounds like your cv joint, but you have to do some research because it is sometimes cheaper to buy the entire half shaft than it is to buy the cv joint, then the labor, its easier to replace the halfshaft than it is to replace the cv joint. So you have to do a little thinkin first
Friday, May 16th, 2008 AT 12:15 AM
DEANTHOMAS1970
Hi again, I have checked the price for the drivers side CV joint and its around $100.00.
But I need to know if there is anything else I need - Seals - Bearings or anything like that.
I do all my own mechanic work so I will also need to know if there is any special tools I will need to get.
Thanks again! Dean
Friday, May 16th, 2008 AT 12:24 AM
LEGITIMATE007
  • 5,121 POSTS
Ayy dean, no Im pretty positive that vehicle doesnt need any seals or anything. And the tools are gonna be just your average, no specialty tools is what im saying. Awesome. Good luck and get back soon
Friday, May 16th, 2008 AT 7:20 AM
