1989 Jeep Cherokee oil pan gasket.
1989 JEEP CHEROKEE
240,000 MILES • 6 CYL • 4WD • AUTOMATIC
STHOMPSON130
can i use a one piece gasket? the other option is a four piece gasket two rubber and two cork. i prefer the one piece perm a dry but the gasket connects to the timing cover, and i believe what i call the rear main oil seal. am i right about the rear main seal ? and can i use a one piece gasket as opposed to the four piece?
Aug 24, 2009 at 11:22 AM
  • 110,244 POSTS
Can you even find a 1 piece?
Aug 24, 2009 at 2:00 PM
STHOMPSON130
yes i have a one piece
Aug 25, 2009 at 8:08 AM
  • 110,244 POSTS
I would say yes then. I hate using cork gaskets because they always seem to leak. Is the one you have a rubber composit?
Aug 25, 2009 at 4:03 PM
STHOMPSON130
its actually made of permatex with what seems to be copper crush style material directly in the center one third the width of the gasket.
Aug 26, 2009 at 8:38 AM
  • 110,244 POSTS
It sounds like a good one. Just make sure that you pean the pan (bolt holes) and don't over tighten it.
Aug 26, 2009 at 1:20 PM
