1989 Jeep Cherokee intermittant high RPM
BILLHUNT77
  • 1989 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 17,400 MILES
To whom it may concern
my jeep runs at2000 rpm, sometimes at start up
this happens sometimes after driving, stopping and
restarting. If I turn vehicle off again for a couple of
minutes it starts at proper rpm.
gatefull for an answer
bill
Friday, June 19th, 2009 AT 12:08 PM
  • 109,885 POSTS
Has the check engine light come on? It sounds like a throttle position sensor or an idle air control valve, but I can't be sure without a code from the computer. Also, you may want to check for vacuum leaks that can cause this and the EGR valve.
Thursday, June 25th, 2009 AT 12:26 AM
