HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jeep
Cherokee
General
Fuse Test
1989 Jeep Cherokee fuse
KEVIN52
MEMBER
1989 JEEP CHEROKEE
6 CYL
4WD
AUTOMATIC
230,000 MILES
Which fuse in bos works reverse lamps
Monday, May 3rd, 2010 AT 12:54 PM
BLUELIGHTNIN6
MECHANIC
Fuse #4 (yellow, 20 amp) in the fuse panel located at lower left side of dash. It also controls rear defogger and turn signals. If fuse is OK check bulbs and back up switch located on left side of transmission case
Monday, May 3rd, 2010 AT 4:51 PM
Please
login
or
register
to post a reply.
Related Fuse Test Content
Can A Fuse Stop A Car From Starting?
I Have Had My Alternator Tested And The Starter Tested And Both Are Good And I Had The Battier Checked And I Replaced It And The Termalast...
Asked by
tj86current
1989
JEEP CHEROKEE
93 Jeep Cherokee Blowing 30 Amp Eng. Cont. Fuse
Hope Some One Can Help Me, My Son Jump Started His Buddies Truck And As He Tells It, He Hooked The Cables Backwards On The Cherokee, He...
Asked by
duckkiller
1993
JEEP CHEROKEE
1991 Jeep Cherokee Blowing Fuses
Electrical Problem 1991 Jeep Cherokee 6 Cyl Four Wheel Drive Automatic Ok This Is The Craziest Thing I Have Ever Dealt With, And I Am...
Asked by
ShinGotti
1991
JEEP CHEROKEE
91 Xj Fuse Blowing
Hi Everyone, I Have A 91 Sport 4.0 That Has Been Having Some Recent Problems Blowing The Fuse That Handles The Tail Lights/instrument...
Asked by
ops5
1991
JEEP CHEROKEE
2000 Jeep Cherokee Fuse Blowing
I Have A No Start Situation Thatstarted With The Engine Missfiring And It's Blowing The #18 Fuse I've Replaced Cpr Sensor Re Index The Cam...
Asked by
bukowy88
2000
JEEP CHEROKEE
VIEW MORE
Misfire
Engine Oil Change and Filter Chevrolet Camaro
Serpentine Belt Replacement
