1989 Jeep Cherokee control modual
189,000 MILES • 6 CYL • 4WD • AUTOMATIC
NOGO1
I am trying to locate the computer control module to change it. the fuel pump voltage drops then the engine stalls. I turn the key off then on again the engine will start but shortly after the fuel pump looses voltage again and stalls.
Nov 22, 2009 at 6:32 AM
  • 110,248 POSTS
Have you checked to make sure the fuel pump relay is good?
As far as the computer, it is in the front seating area, passenger side under the dash, mounted above kick panel.
Nov 22, 2009 at 2:13 PM
