1989 Jeep Cherokee blue smoke
247,000 MILES • 6 CYL • 4WD • AUTOMATIC
JHUTCH
I just recently bought this jeep, and I have started cleaning, degreasing and replacing things. I replaced the valve cover gasket and the pcv tube and now there is blue smoke coming from the exhaust and from under the hood somewhere. I did double check the valve cover bolts and tightened a couple of bolts and still the same. Before replacing the pcv tube I did notice some smoke coming out of this tube. Should I sell it or fix it.
Dec 8, 2008 at 1:19 PM
  • 31,937 POSTS
Hi there,
Blue smoke is oil burning, i would determine if its rings or valve stem seals first, a leak down test will help here, valve stem seals will be a lot cheaper to fix than a ring problem.
Mark (mhpautos)
Dec 8, 2008 at 3:07 PM
