1989 Jeep Cherokee belt
TRINA&LOGAN
  • 1989 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • MANUAL
  • 218,000 MILES
My belt wont stop squealing, we replaced the water pump, nothing happened, we put a new $50 belt on and its still making so much noise. It has to be the belt because when we put water or sometihing on the belt it stops making noise for a minute but then starts again. What should I do next?
Wednesday, May 13th, 2009 AT 1:56 PM
  • 109,885 POSTS
Is the belt tight enough? Also, make sure the pulleys are not glazed. If they are, you will need to try to clean them with a strong cleaner (degreaser) to see if that helps. If you replace the belt, chances are it needs to be a little tighter and double check the routing to make sure it is correctly installed.
Sunday, May 17th, 2009 AT 3:15 PM
