HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jeep
Cherokee
Engine
Cylinder Head
Valve Cover
Gasket
1989 Jeep Cherokee
FERNANDORAMOS22
MEMBER
1989 JEEP CHEROKEE
6 CYL
4WD
MANUAL
250,000 MILES
How can I fix a oil lick that is not coming from the oil pan or the valve cover gasket?
Sunday, November 30th, 2008 AT 12:53 PM
HAYDAVE7
MEMBER
At 250,000 miles it may be mechanically WORN OUT.
Seals and mechanical clearance at the rings could expel
excessive amounts of oil by BLOW BY.
( rebuild the engine or live with it )
dave :'>
SPONSORED LINKS
Monday, December 1st, 2008 AT 10:26 PM
Please
login
or
register
to post a reply.
Related Cylinder Head Valve Cover Gasket Content
1996 Jeep Cherokee Replaced Head
Engine Performance Problem 1996 Jeep Cherokee 6 Cyl Four Wheel Drive Manual Unknow Miles Just Replaced Head After Bad Overheat And...
Asked by
edgates
1996
JEEP CHEROKEE
GUIDE
Valve Cover Gasket Replacement
A valve cover gasket is located between the engine block and cylinder head and is used to stop engine oil from leaking from the valve cover.
Cracked Cylinder Head
I Am Working On A 2000 Jeep Cherokee 4x4. It Came In The Shop With A 8 Inch Crack In The Cylinder Head With A Blown Head Gasket, But Was...
Asked by
tyranger
2000
JEEP CHEROKEE
1994 Jeep Cherokee Head Bolt Sequence
I Am Trying To Find Out The Proper Sequence And Specs For Tightening The Head Bolts.
Asked by
blsc309
1 ANSWER
1994
JEEP CHEROKEE
2003 Jeep Cherokee Valve Train
#4 Cyl. Rocker Arm Fell Out Without No Signs Of Any Problems. Such As Ticking Or Missfireing. No Signs Of Wear Or Broken Or Bent Valve...
Asked by
a1rp1pl
1 ANSWER
2003
JEEP CHEROKEE
1991 Jeep Cherokee Torque Specs
Need Torque Specs For Cylinder Head Bolts
Asked by
a.bocanegra
1 ANSWER
1991
JEEP CHEROKEE
VIEW MORE
SPONSORED LINKS
Engine Oil Leak
Change Oil and Filter BMW 328i
Oil Change and Filter Replacement Toyota
Online car repair manuals
