I believe it is a throttle body injection, I have no idea about the solinoid, the a/c doesn't work as far as I know, to be honest I dont think the instrument panel is working so no lights come on at start up or even when driving, I promise I have not toyed with the adjustments, i'm no good at those anyway, so I stay away, (but possible to have been messed with before I bought it a week ago) that could be the problem.
Also I have found a vacuum hose that is fitted shaped witha elbo that was just loose, i've looked for days on where it might have gone but to no succes, the only thing I can find that is close is on the engine side of the throat there is a vacuum line running into a rubber fitting and the rubber fitting looks like it was supposed to have two lines running into it, but there is only one, that one runs to an electric device at about the top rear of the engine bay just above the engine,
i pulled off the idle air control valve it looks okay, but I dont know hao to test it
SPONSORED LINKS
Saturday, October 31st, 2009 AT 2:31 PM
