1988 Jeep Cherokee Oil in the air Filter
1988 JEEP CHEROKEE
147,000 MILES • 6 CYL • 4WD • AUTOMATIC
VICTOR BUMGARDNER
The air filter becomes soaked with oil in about two months. the engine has no pcv valve, just a tube from the valve cover to a plastic manifold then to the air cleaner box. This is where the oil is coming from. The oil pressure is within normal specs. other than this, the engine runs fine.
Apr 17, 2008 at 6:38 AM
LEGITIMATE007
  • 5,121 POSTS
make sure that hose is not clogged.
Apr 17, 2008 at 8:08 AM
