1987 Jeep Cherokee Low oil pressure when hot
CAVEMANLAWYER
Engine Mechanical problem
1987 Jeep Cherokee 6 cyl Four Wheel Drive Manual 200k miles
I have an 87 Jeep cherokee with 200k miles on it. Cold oil psi = 40 .The problem happens when the engine gets hot and over enough distance (40 miles) my oil pressure slowly drops to zero. I have gone with thicker oils, I have replaced oil filters, I have tested the dash gauge, I have I have I have... Any ideas? thanks.
Mar 30, 2009 at 2:10 PM
BLACKOP555
  • 10,386 POSTS
check the oil pump and the oil pressure regulator.
are you using a thread in guage not relaying off the guage on the insrument cluster?
Mar 30, 2009 at 2:55 PM
