Hi, thanks for the donation. Any applicable trouble codes? What was the fuel pressure spec, 31--39psi. Use a noid lite, see if injectors have voltage and ground.
You should be able to get mil codes by cycling the ignition switch, fuel injected engines. You turn the key just till the dash lites come on, no further. You cycle the key, on--off, on--off, on--off, on, then the mil start flashing, you count the flashes to get the codes.
SPONSORED LINKS
Sunday, March 28th, 2010 AT 9:40 AM
