1986 Jeep Cherokee
218,000 MILES • 4 CYL • 4WD • MANUAL
STILWELL
My jeep will start and then die, im getting fuel and I have replaced the plugs, cap, rotor, plug wires, and crankshaft position sensor, what else can I do?
Aug 21, 2009 at 4:51 AM
  • 110,248 POSTS
Has the check engine light come on? Have you checked the catylatic converter for plugging? Has the fuel pressure been tested? And finally, (I can't remember) is the 86 fuel injected or does it have a carb? I remember having trouble with the carbs coming loose and causing this type of problem. Also, check for vacuum leaks. If all checks out ok, I would run a compression test. That is a lot of miles for a 4cyl in one.
Aug 24, 2009 at 2:35 PM
