1985 Jeep Cherokee oil pressure problem
1985 JEEP CHEROKEE
91,000 MILES • 6 CYL • 4WD • AUTOMATIC
SCHAFD50
when i start my jeep i have around 40 pounds of pressure but after five minutes it goes down to almost zero. the motor doesnt make any ticking noises at all, but sometimes the vehicle makes a wierd noise when im on the gas pedal over 2000 rpms. i cant tell if its my exhaust because it is a little loose. what should i do is it my oil sending unit or what?
- also i have a leaking trans that i have replaced the gasket recently but began to leak again. most of the time when i put it in reverse it doesnt engage right away, it takes about five seconds or more, this also happens in drive sometimes also. Could the noise be coming from my trans?
Jan 24, 2008 at 5:54 AM
Get the oil pressure checked Now before you end up with major repairs. Hook up an oil pressure tester-if its normal-replace the oil sending unit. If not could mean oil pump/bearings/galleries etc in there.
Jan 24, 2008 at 5:58 AM
