1985 Jeep Cherokee 1985 Jeep Cherokee Delays to move on fir
1985 JEEP CHEROKEE
KONRADW
Transmission problem
1985 Jeep Cherokee 4 cyl Two Wheel Drive Automatic alot miles
Hello, in the mornings when I start my jeep it idles fine(actually high idle but thats a diferent matter). but when I put it in any gear (forward reverse or other) and apply the pedal, the engine whirs away and no motion to the wheels, mind you it only lasts for about 5 seconds and the vehicle crawls into motion, then after twenty seconds or so is running as normal.
In the afternoons at lunch or in the evenings I dont have this problem.
cheers for the answer/suggestion and a good site.
I also have the haynes repair manual for this vehicle, is thee a particular section that should interest me..lol
Good day
Sep 7, 2010 at 5:21 AM
CJ MEDEVAC
  • 11,004 POSTS
See my profile........Imma CJ GUY...I do not know your rig.
WOW! somebody has a manual!!!
You are now my favorite question asker!
Sounds like a tranny problem.....See scheduled maintenence in your MANUAL.
Have you kept up?
It may be worse.....But I suspect you need to do a Filter/ fluid change on your tranny
I have had good luck doing this on friends' cars...usually the filter was really stopped up, fluid could not get thru fast enough to make things work.
Won't hurt anyway....should probably have needed it regardless.
That BOOK is a very smart thing to own! I have learned alot from the 25 or so I have.
Read it like a novel once, use it like a dictionary thereafter.
Respond?.....Me CJ Guy, trying to assist.
I'm not a Paid Mechanic.....but do and know alot, sorta a "Rear Lawn Jeep CJ/ Auto Technician"
I am a member, just like you. I have sorta earned the "HELPER TITLE" here, my profile will show you how much I answer, "Votes" show you my reputation here. "FEEDBACK" is for you to rate me.
Keep me informed soon,
This is my hobby, I live for responses!
The Medic
Sep 8, 2010 at 1:54 PM
