02 jeep grand cherokee 98k 4.0
2002 JEEP CHEROKEE
ENJOI78
signal lights going crazy. with out touching the switch either the right signal or hazard light goes on. when it finally stops and i go to use one of the signal lights the hazard lights go on. i changes the relay and the switch and still does the same any help?
Feb 19, 2007 at 9:01 AM
2CARPRO JACK
  • 11,533 POSTS
Do all other lights in your Jeep work correctly? Brake, running..........
Feb 19, 2007 at 9:15 AM
ENJOI78
yup n its driving me nuts everything works fine except the signals
Feb 19, 2007 at 10:35 AM
2CARPRO JACK
  • 11,533 POSTS
When the turn signal switch was replaced do you know if the wiring in the column was checked out for chaffing or shorting?
Feb 19, 2007 at 10:54 AM
ENJOI78
i checked it myself but i gave up its at the dealer
Feb 20, 2007 at 10:30 AM
