My vehicle cant start. It back fires through the throttlebody when turning the engine.initially it showed fault code for intermittent CPK ,stuck transmission shift solenoid and injector 1 misfire.I had it filled with gas to the bream as I was making a long trip and that's when all hell broke lose.It had no power,and was running as if its cutting fuel (pulsating) and it also increased fuel consumption significantly.It finally died as I was about to reach home.I put in a set of upgraded (4 hole) fuel injectors,changed CPK and Camshaft sensor, no difference.can u please help me to trouble shoot the problem.
Dec 10, 2013 at 9:02 PM
