2001 Jaguar XKR HESITATION
JEAN-YVES
  • 2001 JAGUAR XKR
Engine Performance problem
2001 Jaguar XKR V8 Two Wheel Drive Automatic
hello my jag has a hesitation on hard accelaration from a stop the engine light is on and some time the restricted performance comes on some time.
Sunday, May 16th, 2010 AT 7:48 PM
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis, finding out what's going on.
Sunday, May 16th, 2010 AT 11:11 PM
JEAN-YVES
WELL DID BRING IT TO GARAGE THEY CHANGE FUEL FILTER AND THE CODE READING SHOWED TWO CODES FIRST ONE PO171 THEY SAID BANK 1 LEAN, THE SECOND CODE SAID PO174 BANK 2 LEAN CAN SOMEONE HELP ME BY SAYING WHAT I HAVE TO DO THANKS.
Tuesday, May 18th, 2010 AT 5:47 PM
Lean fuel condition could be caused by one of the following below:
1. Vacuum leaks
2. EGR and PCV valve.
3. Low fuel pressure.
4. Dirty fuel injectors.
5. Mass Air Flow Sensor.
Tuesday, May 18th, 2010 AT 8:27 PM
