i have an 05 xk8. i replaced the front brakes yesterday and had the rotors turned. i compressed the pistons into the calipers without opening the system, put the pads in and put it back together. i started the car and the pedal went all the way to the floor. i can pump them up and have good pedal. drove it around the block and the same thing. you have to pump the pedal to have brakes. then i bled all 4 calipers twice and still have the same result. there is air somwhere in the system and i am puzzled as to how to get it out. any help would be appreciated.
Jul 3, 2010 at 1:40 AM
