2002 Jaguar XK8 Car stops will not start
2002 JAGUAR XK8
42,000 MILES • V8 • 2WD • AUTOMATIC
CRAIG EBNER
  • 5 POSTS
I have had a number of times that my Jaguar XK8 will stop and when i turn the key nothing happens. Battery is new and they have replaced 2 starter switches. In two weeks after the last switch I turned off the car and when i tried to start it again nothing. No gauges no electrical. They tried replacing the switch again but this time it did not correct the problem. The mechanic said he has checked the wires and starter motor but does not have an analyzer. Unfortunately i have little faith in my closest Jaguar dealer.
Do you have any ideas?
May 28, 2009 at 4:43 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Check high power fuses in trunk next to battery. See if the 500 amp and the 250 amp are good.
Let me know
Thanks for donate
May 28, 2009 at 5:33 AM
CRAIG EBNER
  • 5 POSTS
The high current fuses are OK
May 30, 2009 at 12:16 AM
CRAIG EBNER
  • 5 POSTS
I have additional info on the problem that might help.
It appeared that the battery(although new) needed to be charged. When charged I got a quick flash indication of all the status lights on the dash ( engine symbol etc) but then they go out again and it will not start but battery appears to be down in charge
May 30, 2009 at 1:51 AM
DOCFIXIT
  • 18,828 POSTS
What is voltage of battery across posts? it is possible battery has a dead cell oe a shorted cell. Try new battery or jump.
May 30, 2009 at 3:05 AM
CRAIG EBNER
  • 5 POSTS
I was able to jump start the car with a 500 AMP jumper but it soon stopped which i assume means the battery is discharged. It is a new battery within 6 weeks. Could it be the altenator not charging or starter motor draining the battery?
Thank You
Craig
Jun 2, 2009 at 2:27 AM
DOCFIXIT
  • 18,828 POSTS
Alternator most likely can't test till good battery is in car. When good batt is installed check starter draw and alt output.
Let me know
Jun 2, 2009 at 4:22 AM
CRAIG EBNER
  • 5 POSTS
Found it was one of the ignition relays that was bad. The battery is fine.
Thank You for your assistance
Craig
Jun 2, 2009 at 7:55 AM
DOCFIXIT
  • 18,828 POSTS
Good to hear you did a good diagnostic job.
Jun 2, 2009 at 8:05 AM
