2001 Jaguar XK8 trac not available message light on.
80,000 MILES • V8 • 2WD • AUTOMATIC
PAULTOY11
trac not available message light comes on. Also the ABS light comes on. both will stay on. Then there are times I get no lights. What is the cause for this?
Feb 10, 2010 at 7:08 AM
2CARPRO JACK
  • 11,533 POSTS
The traction control and ABS systems work together.If one has an issue it will almost always affect the other.You will need to have the computer scanned for codes in the ABS/Trac control system to see what the computer is logging as a system failure.Once we get the code/codes we can go from there
Feb 10, 2010 at 11:23 PM
