2000 Jaguar XK8 Instrument cluster lighting
2000 JAGUAR XK8
63,000 MILES • V8 • 2WD • AUTOMATIC
DAVEROBINSON
Last week when I went to drive home at night, my instrument lighting did not work when the headlights are on. When I put the key in the ignition they are on, but when I rotate the lighting stick to put on the headlights the instrument lighting shuts off. I checked the dimmer switch to make sure that it is not turned down and that is not the case. Any ideas?
Sep 7, 2010 at 10:50 PM
PLANETPULEO
Mine did the same thing.It was a 10 amp fuse on pass side inner dash.
Sep 17, 2010 at 3:47 PM
