1999 Jaguar XK8 XK8 converatible top
1999 JAGUAR XK8
46,000 MILES • V8 • 2WD • AUTOMATIC
SALZAF1
I was trying to open top and the fluid leaked from the backview mirror assembly, so I locked it manually with the supplied tool and ordered repair kit from Jagbit. My mechanic (not Jag mechanic) repaired the fluid lines using the kit. Now when I push the button, the small window glass goes down as it suppose to, and I can hear the motor run in the trunk, but the top won't open. Am I missing a step here, what should be done. Thanks and Regards.
Sal
Jul 15, 2009 at 11:19 AM
  • 31,937 POSTS
HI there, Thank you for the donation, I am not a Jag mechanic but reading the operation system, i see that there is a by-pass valve that you turn to manually operate the roof, now if that valve was not re set i feel that the hydraulics will be over ridden and not operate the roof,the 1/4 vent is electric and not governed by that part of the system, just a thought have a look at the valve. mark (mhpautos)
https://images.2carpros.com/forum/automotive_pictures/61395_1_23.jpg
Jul 15, 2009 at 10:19 PM
