1997 Jaguar XK8 Passenger Seat
1997 JAGUAR XK8
75,000 MILES • V8 • 2WD • AUTOMATIC
DICKKING
The passenger seat back does not go forward or back. I hear a click when I press the middle button.
The fuse location under the hood is missing the 20 A fuse for the seat, but there are no contact in the fuse holder to hold a fuse. Is there any way to manually move the back of the seat forward? Any other ideas on what could be the problem.
Thanks,
Aug 20, 2010 at 5:41 AM
JAGTECH360
  • 74 POSTS
Most common failure is the seat control module. Really the only way to move it would be to supply power and ground to the appropriate seat motor which will not be easy as chances are you will not be able to get the seat out. The module can be seen and accessed from below the front of the seat.
Nov 2, 2010 at 12:34 PM
