1997 Jaguar XK8 Ignition
JPERRY14
  • 1997 JAGUAR XK8
  • V8
  • 120,000 MILES
I can turn the ignition off on my 97 XK8 but the car continues to run and the ony way I can turn it off is to shake the battery and it turns off instantly. What seem to be the problem?
Saturday, October 9th, 2010 AT 6:54 PM
JAGTECH360
  • 74 POSTS
There is a connector near the battery. It is a two wire white connector. Be sure this is not touching anything and that is doesn't have corrosion on the terminals. It is a transit relay connector that is used during shipment from the factory. It will keep the car running if it is setting in some water, touching any metal, or corroded.
Tuesday, November 2nd, 2010 AT 7:37 PM
