1997 Jaguar XK8 drivers power window
1997 JAGUAR XK8
62,000 MILES • V8 • 2WD • AUTOMATIC
HARRY JONES
car is a convertible and when the door is opened the window is supposed to drop approximately one half inch and go back up when the door is closed. the window on my car will NOT go back up automaticly when the door is closed. Resetting the memory does not help. The window keeps dropping more each time the door is opened. the window operates correctly with the inside switch, just will not go back automaticly when the door is closed. The passenger window operates correctly.
Apr 21, 2010 at 8:40 AM
DAVE H
  • 13,384 POSTS
Recheck alignment of glass, raising an lowering glass several times. Readjust if necessary. Raise glass to fully closed position and disconnect battery from motor. Loosen regulator up-stop bolt. See Fig. 2 . Move stop rearward to abut regulator quadrant, and tighten regulator up-stop bolt.
https://images.2carpros.com/forum/automotive_pictures/266999_jag_106.jpg
Apr 21, 2010 at 8:33 PM
HARRY JONES
Glass is not out of alignment in any way. I think it has to be an electrical or computer probem. Your thoughts ???????
Apr 22, 2010 at 8:36 AM
DAVE H
  • 13,384 POSTS
Sorry for the daly in response, work commitment's etc.
My next step would be to replace the DDCM .. (Driver Door Control Module In driver door)
The door windows are controlled by Driver Door Control Module (DDCM) with input from switches located on driver door armrests. When passenger windows are operated from driver door switches, the DDCM transmits a Standard Corporate Protocol (SCP) message to selected door control module. Pressing a passenger window switch inputs directly to selected door control module. Pressing rear portion of window switch will lower window, while pressing front of switch will raise window.
One-touch open is a feature of the power window system. If a window switch is pressed for 50-250 milliseconds, the window will open fully. If switch is held longer than 250 milliseconds, window will stop at position it is in when switch is released.
To protect power window motors, a thermal cut-out (circuit breaker) operates if system is overloaded. If circuit breaker is overheated, it will require about 5 seconds to reset before system will operate again. Window switch must be released to enable circuit breaker to reset.
On XK8 convertible models, door windows will lower 0.47" (12 mm) when door opens or top is lowered, and will raise fully when door is closed and top is raised and latched. Rear quarter windows will lower completely when top is lowered, and will not be allowed to raise until top is raised.
Apr 23, 2010 at 8:05 PM
