s type jaguar 3 ltr 2000 heater probles
DUG1
heater has stopped working already replaced the control valve worked for a while then stopped again just blows cold air thought it could be an air lock but can find bleed screw any sugestions please :?
Nov 25, 2006 at 2:46 AM
FSTRANGER302
  • 117 POSTS
yes there is a bleed valve under the throttle body but becarefull it will break easy. also the s types had wiring issues. for the heater valve. check for voltage in the center wire of the connector. if there is no voltage you have a wiring issue. the wiring is located under the drivers inner fender good luck
Dec 19, 2006 at 1:28 PM
