P0174
SHAHYARS
[code:1:c5c51afb96]P0174,P0171
i have a 2000 jaguar stype 3.0 the check engine light came on and when i scaned it with a machine at auto parts store i got these two codes.
i heared it could be the maf sensor. have any ideas. also anyone know of any websites to see the location of maf sensor on the car
thank you [/code:1:c5c51afb96]
Mar 8, 2006 at 1:34 AM
BESTGRIPAJAG
  • 13 POSTS
I dont know of a website but the maf sensor comes of the intake on the plastic tube next to the air filter.Also this problem may not be the maf sensor but could be an air leak around the intake check for leaks! good luck! :D
Mar 16, 2006 at 1:41 AM
JAGTECH06
  • 7 POSTS
P0174 is an EVAP code. Usually tends to a breather elbow beneath the intake manifold. There is a recall on your year model on this piece. This will tend to make the car run lean. The elbow begins to wear and then make a hole. Check for a whistling noise under the hood while the car is cranked.
Oct 17, 2006 at 5:24 PM
