Driver side window on 00 s-type won't go up all the way
2000S-TYPE
My driver side window works well except that when it gets to the rubber moulding on the window frame it stops and doesn't go up anymore. I did notice that when I push it up with my hands the glass moves from side to side, can someone help? Thanks
Apr 6, 2006 at 4:50 AM
2CARPRO JACK
  • 11,533 POSTS
sounds like the guide or regulator are having a problem. Be careful the door panel has to come off and you dont want to mar it
Apr 6, 2006 at 10:07 AM
2000S-TYPE
I took the panel off, no problem there; however upon inspecting the area everything seems fine except for a few pieces of white plastic I found at the bottom of the door. I match them up and they seem to be some sort of small bracket. Also after putting the door panel back it seems the window is going up sluggish. Another thing, I see that everyone always mentions the regulator when talking about power windows, are they referring to the motor?
Apr 7, 2006 at 1:03 AM
FSTRANGER302
  • 117 POSTS
hello what you need to fix this problem is a window regulator. the plastic you foundis for the guides.
pretty soon if not already the regulator will stop all together going up and down
Sep 20, 2006 at 1:12 PM
