2000 Jaguar S type 3.0
KITTYHAWK
My car turns off at stop signs and red lights. When the vehicle is running at over 30 miles it seems to run ok though. The car is very shaky as it comes to a stop and it usually turns off when I come to a stop. I usually just put it in neutral and rev the engine. My car has had this problem for months now and although I had the upper and lower intake gasket replaced it is still doing the same thing. The two fault codes are P0171 and P0174. Thank you for your help!
Apr 11, 2007 at 5:24 AM
MARSEL
I have the same problem with my 2000 Jaguar S type 3.0, I have vacuum leak and when I open the hood I can hear the air being sucked in from a bad intake gasket.
I would open the hood and see if you can hear a "hissssing" noise, maybe you have vacuum leak.
Apr 30, 2008 at 3:16 AM
