1999 Jaguar S-Type Uneven Cabin Heat
LEEWRIGHT
The cabin heater is not controlling. When ignition is turned on it all works perfectly, howver when I start the engine there is a temperature differential between the passenger side and the driver side. Both get hotter as the car engine warms up and the engine accelerates. The heater control valve has been replaced twice, the second time by a Jaguar dealership. I've checked the air intake flaps and they are all working ok. Any helpful suggestions would be appreciated.
Jun 20, 2006 at 10:57 AM
2CARPRO JACK
  • 11,533 POSTS
there has to be some kind of temp sensors to tell the climate control how hot/cold its getting
Sep 12, 2006 at 7:42 AM
FSTRANGER302
  • 117 POSTS
there are three sensors in the heater box that if one is not right your heat will be different. unfournatly. only the dealer can figure which one using datalogger. or you can replace all three
Sep 20, 2006 at 1:39 PM
Suggested Repair
Check the three temperature sensors in the heater box. A dealer can identify the faulty sensor with a datalogger, or all three sensors can be replaced.
Conversation Summary
The owner of a 1999 Jaguar S-Type reports uneven cabin heat between the driver and passenger sides after the engine starts, even though the system works with the ignition on. Heat rises as the engine warms and accelerates. The heater control valve was replaced twice and the air intake flaps work. Experts say heater-box temperature sensors tell the climate control the temperature, and a bad sensor among the three can cause uneven heat. A dealer can identify the faulty sensor with a datalogger, or all three can be replaced.
