1996 Jaguar XJS Won't start
34,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAGUARXJS
Turns over great, can smell gas coming out the exhaust. No spark at all. looking for th first things i should check.
Thanks alot
Rick
Jul 20, 2008 at 6:54 AM
DAVE H
  • 13,383 POSTS
4.0L
Ignition timing and spark distribution are controlled by PCM according to sensor inputs. Ignition timing is controlled primarily as a function of engine load and speed. Engine load is sensed by Mass Airflow (MAF) sensor. Engine speed is sensed by a Crankshaft Position (CKP) sensor. The PCM processes inputs from the sensors and accesses ignition timing from the ignition timing strategy. Individual ignition coils are located above each spark plug (total of 6 coils). PCM incorporates the primary circuit for each coil and provides switching for each primary circuit. The correct firing sequence and timing of the 6 coils is determined by PCM from cylinder synchronization input provided by the Camshaft Position (CMP) sensor.
Jan 9, 2010 at 9:49 PM
