1996 Jaguar XJS loss of transmission fluid
102,000 MILES • 6 CYL • 2WD • AUTOMATIC
POWERCAT
The car was running fine then suddenly dumped out most of the transmission fluid, mostly onto the right hand exhaust pipe, over about 25 miles. When stopped the car does not drip fluid. The only change I made was switching from S to N transmission mode. (May not be relevant.) What is the problem?
Jul 20, 2008 at 5:36 PM
  • 31,937 POSTS
Hi there,
I think you may have split a oil cooler pipe, you best get this checked before you drive it again.
Mark (mhpautos)
Jul 20, 2008 at 7:15 PM
POWERCAT
Spot on!!
Jul 21, 2008 at 11:34 AM
