1995 Jaguar XJS left and right windows
118,000 MILES • 6 CYL • 2WD • AUTOMATIC
GUIYING
hi guys spilled coffee on my center controls windows do not go up or down......i am thinking it could be fuses or relays.......if so where are they located ?......
May 12, 2010 at 9:03 AM
2CARPRO JACK
  • 11,533 POSTS
First, I apologize for the delay in answering your question.Check fuse 17 in the left fuse panel.Ifit is ok, you may have taken out the aux load relay in tehright fuse panel.Before you go to therelay if thefuse is good, pop the panel off to access theswitchs.Use atest light and check for power (brown/blue wires)
May 17, 2010 at 1:04 AM
