1995 Jaguar XJS Fuel Guage
49,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROBERT CLARK
I have a fuel guage that does not work properly. I have just replaced the in tank sending unit and I still have the same problem. Can I remove the fuel guage from my dash to send out for a repair? I so can you provide any instructions on how to remove the guage from the dash cluster?
Thank you,
Bob Clark
Jun 8, 2008 at 4:51 AM
DAVE H
  • 13,383 POSTS
INSTRUMENT CLUSTER
Removal & Installation (Instrument Panel Module)
Disconnect battery ground. Move tilt steering column to lowest possible position. Remove instrument panel bezel securing screws, and remove central and side bezels. Remove instrument panel-to-fascia screw cover plates and screws. Ease panel forward for access and disconnect multiplugs. Remove instrument panel. To install, reverse removal procedure. See Fig. 2 through Fig. 4 .
Fig. 2: View Of Instrument Cluster & Terminal Sockets (1 Of 3)
Courtesy of JAGUAR CARS, INC.
Fig. 3: View Of Instrument Cluster & Terminal Sockets (2 Of 3)
Fig. 4: View Of Instrument Cluster & Terminal Sockets (3 Of 3)
Removal & Installation (Instrument Printed Circuit)
Remove instrument panel. Place a protective cover on work bench and position instrument panel face down on cover. Remove illumination bulbs and printed circuit securing nut rubber covers. Remove printed circuit-to-instrument panel securing nuts, and remove printed circuit from instrument panel. To install, reverse removal procedure. See Fig. 5 .
NOTE:Ensure printed circuits are not torn or deformed.
Jan 9, 2010 at 9:25 PM
