1995 Jaguar XJS car won't crank
999,999 MILES • 6 CYL • 2WD • AUTOMATIC
RUBIN2101
the car turns over, not getting any fire to the engine.
put gas in the intake. it still won't crank. I previously had trouble with a damaged hose to the radiator and got that repaired. after that, I drove the car and it won't move.
Dec 3, 2008 at 2:19 PM
  • 31,937 POSTS
Hi there,
You will have to check for spark, if you have no spark, start with getting a diagnostic test done to check for any set fault codes, this may give you a clue as to where the problem lies, start here.
Mark (mhpautos)
Dec 3, 2008 at 2:56 PM
