1995 Jaguar XJS Air Conditioning gets very warm
129,000 MILES • 6 CYL • 2WD • AUTOMATIC
VASQUFR
My 1995 Jaguar AC gets warm when the car is not moving. I have noticed when I am sitting in traffic if the electric fan turns on the ac cools down a lot. Now on my hoda accord when i turn on the AC the electirc fans comes on right away is there a problem with a relay or something?
Oct 12, 2009 at 6:10 AM
MIKE H R
  • 3,094 POSTS
I would have the a/c checked. The way it sounds is that the freon could be low or the system needs recharging.
Oct 13, 2009 at 4:47 AM
VASQUFR
AC has been checked and fully charged. Even if you press the gas pedel and raise the rpms the problem will continue un less the fan turns on or the car is moving. You then feels that eventuly the air gets cold again. I also bypaaased the fan and had it stay on like my honda accord and the ac stays cold.
Oct 13, 2009 at 6:10 AM
MIKE H R
  • 3,094 POSTS
I am trying to locate where the problem could be. A couple of questions, does the fans come on if the car gets hot, what I mean do they run normally when a/c is off. If you turn the heat to defrost does it come on?
Oct 13, 2009 at 10:45 AM
VASQUFR
The fan will come on when the car gets hot but it is pretty hot as in the temp gage is getting into the red and it will cool the car down the ac will get cooler also. This scenario occurs when in traffic as the car is sits. When I turn the defroster on if I have the ac button on the fan does not turn on and also if the ac is off the fan will not turn on.
Oct 14, 2009 at 8:23 AM
DOCFIXIT
  • 18,828 POSTS
Check fan relay with AC on fan should be on. Check voltage at fan maybe motor.
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_188.jpg
Oct 14, 2009 at 8:40 AM
